  3. missing dollarEqualParams in capacitor subckt in auCdl ...
  • Views 14827
missing dollarEqualParams in capacitor subckt in auCdl netlist
Paulux
Paulux over 15 years ago
I want to make these lines in auCdl netlist.
.SUBCKT umim PLUS MINUS
CC0 PLUS MINUS 1.5E-4*cw*cl $[CA] $L=cl $W=cw
.ENDS
XC1 out gnd! /umim cl=20 cw=20
But auCdl netlist gives
CC0 PLUS MINUS (cw)*(cl) $[CA]
.ENDS
XC1 out gnd! / umim cl=20 cw=20
From Virtuoso Analog Design Environment User Guide Product Version 5.1.41, p.629,  only C or area or (L&W) will be outputted in the netlist. How could I make auCdl netlist shown above lines?
Also dollarEqualParams cannot be printed even after I type in CDF as shown below.But from manual, $L=cl $W=cw should be printed when I type into the field of dollarEqualParams, why this cannot happen?
Thanks in advance for your help
The umim CDF is
let( ( libId cellId cdfId )
    unless( cellId = ddGetObj( LIBRARY CELL )
        error( "Could not get cell %s." CELL )
    when( cdfId = cdfGetBaseCellCDF( cellId )
        cdfDeleteCDF( cdfId )
    cdfId  = cdfCreateBaseCellCDF( cellId )
    ;;; Parameters
    cdfCreateParam( cdfId
        ?name           "cl"
        ?prompt         "cl"
        ?defValue       "15"
        ?type           "string"
        ?parseAsCEL     "yes"
        ?name           "cw"
        ?prompt         "cw"
        ?defValue       "15"
        ?type           "string"
        ?parseAsCEL     "yes"
    ;;; Simulator Information
    cdfId->simInfo = list( nil )
    cdfId->simInfo->ams = '( nil )
    cdfId->simInfo->auCdl = '( nil
        dollarEqualParams nil
        dollarParams      nil
        modelName         ""
        propMapping       nil
        instParameters    nil
        namePrefix        "X"
        termOrder         ("PLUS" "MINUS")
        componentName     subcircuit
        netlistProcedure  ansCdlSubcktCall
    cdfId->simInfo->cdsSpice = '( nil
        namePrefix        "X"
        termOrder         ("MINUS" "PLUS")
        componentName     "subcircuit"
        macroArguments    ("cl" "cw")
        netlistProcedure  ansSpiceSubcktCall
    cdfId->simInfo->hspiceD = '( nil
        namePrefix        "X"
        netlistProcedure  nil
    cdfId->simInfo->hspiceS = '( nil
        namePrefix        "X"
    cdfId->simInfo->spectre = '( nil
        modelParamExprList nil
        optParamExprList  nil
        opParamExprList   nil
        stringParameters  nil
        propMapping       nil
        termMapping       nil
        instParameters    nil
        otherParameters   (cl cw)
    cdfId->simInfo->spectreS = '( nil
        namePrefix        "X"
The mim1 CDF is
    ;;; Parameters
        ?name           "l"
        ?prompt         "Length"
        ?defValue       "pPar(\"cl\")"
        ?type           "string"
        ?display        "artParameterInToolDisplay('l)"
        ?parseAsCEL     "yes"
        ?name           "w"
        ?prompt         "Width"
        ?defValue       "pPar(\"cw\")"
        ?type           "string"
        ?display        "artParameterInToolDisplay('w)"
        ?parseAsCEL     "yes"
        ?name           "c"
        ?prompt         "Capacitance"
        ?defValue       ""
        ?type           "string"
        ?display        "artParameterInToolDisplay('c)"
        ?parseAsCEL     "yes"
        ?name           "ic"
        ?prompt         "Initial condition"
        ?units          "voltage"
        ?defValue       ""
        ?type           "string"
        ?display        "artParameterInToolDisplay('ic)"
        ?parseAsNumber  "yes"
        ?parseAsCEL     "yes"
        ?name           "model"
        ?prompt         "Model name"
        ?defValue       ""
        ?type           "string"
        ?display        "artParameterInToolDisplay('model)"
        ?parseAsCEL     "yes"
        ?name           "m"
        ?prompt         "Multiplier"
        ?defValue       ""
        ?type           "string"
        ?display        "artParameterInToolDisplay('m)"
        ?parseAsCEL     "yes"
        ?name           "scale"
        ?prompt         "Scale factor"
        ?defValue       ""
        ?type           "string"
        ?display        "artParameterInToolDisplay('scale)"
        ?parseAsCEL     "yes"
        dollarEqualParams (cl cw)
        dollarParams      nil
        netlistProcedure  ansCdlCompPrim
        instParameters    (L W)
        componentName     cap
        termOrder         (PLUS MINUS)
        propMapping       (nil L l W w)
        namePrefix        "C"
        modelName         "CA"
        propMapping       nil
        netlistProcedure  ansSpiceCompPrim
        instParameters    (c ic)
        componentName     cap
        namePrefix        "C"
        current           port
        termMapping       (nil PLUS "" MINUS "(FUNCTION minus(root(\"PLUS\")))")
        noPortDelimiter   t
        dcSens            nil
        acSens            t
        propMapping       nil
        namePrefix        ""
        otherParameters   (model)
        instParameters    (c w l m scale trise ic tc1 tc2)
        termMapping       (nil PLUS \:1 MINUS "(FUNCTION minus(root(\"PLUS\")))")
        componentName     capacitor
        propMapping       nil
        netlistProcedure  ansSpectreSCompPrim
        instParameters    (c w l m scale trise tc1 tc2 ic)
        namePrefix        "C"
        noPortDelimiter   t
        current           port
Thanks in advance for your help.
