  3. parameter sweep in ADEGXL?
  • Views 14589
minci
minci over 15 years ago
Hi,there
 Does ADEGXL in IC614 have parameter sweep function? I cannot find it anywhere in all panels.
Regards
    Yes. In the data view assistant, in the global variables, you can either click on the value, and type in a list of values or a matlab type start:step:stop syntax, or click on the ellipsis (...) next to the value to fill in a form. There's even a tooltip over the value in the global variable list to explain this.
