  3. strmout flatten gds file
  • Views 15580
sathisha
sathisha over 15 years ago
Hi How to strmout a gds file by flattening all the instances inside the cell. I am using this command strmout -library m28_111hs -strmfile m111hs_smp.gds2 -topcell m111hs_smp -view layout -logFile m28_111uhd.strmout -techLib 28nm_master -hierDepth 32 -layerMap stream_out.map -propMap strm_prop_map -doNotPreservePcellPins -flattenPcells -flattenVias -case preserve -pathToPolygon do i need to add anything? Thanks, Sathisha
  • Quek
    Quek over 15 years ago
    Already answered by Andrew. : )
