  3. Stremout Flatten gds
  • Views 17549
sathisha
sathisha over 15 years ago
Hi, How to strmout a gds file by flattening all the instances inside the cell. I am using this command :- strmout -library -strmfile -topcell -view layout -logFile file.strmout -techLib r -hierDepth 32 -layerMap stream_out.map -propMap strm_prop_map -doNotPreservePcellPins -flattenPcells -flattenVias -case preserve -pathToPolygon do i need to add anything? Thanks, Sathisha
    There's no option in the stream out command to flatten the layout. You'd have to do it with some SKILL first (e.g dbFlattenInst) and then stream out the result - or use a physical verification tool to read the stream, flatten, and write out a flattened stream file.
    Best Regards,
