  3. virtuoso license error_RHEL4
  • Views 17501
MAAC
MAAC over 15 years ago
I'm trying to install the virtuoso and am facing some issues while uping the license. Below is the log details. Wht is the solution for the below error?
[root@192 ~]# cd cadence
[root@192 cadence]# cshrc
bash: cshrc: command not found
[root@192 ~/cadence]$ source path
[root@192 ~/cadence]$ lmgrd -c license.txt
13:51:26 (lmgrd) -----------------------------------------------
13:51:26 (lmgrd)   Please Note:
13:51:26 (lmgrd)
13:51:26 (lmgrd)   This log is intended for debug purposes only.
13:51:26 (lmgrd)   In order to capture accurate license
13:51:26 (lmgrd)   usage data into an organized repository,
13:51:26 (lmgrd)   please enable report logging. Use Macrovision's
13:51:26 (lmgrd)   software license administration  solution,
13:51:26 (lmgrd)   FLEXnet Manager, to  readily gain visibility
13:51:26 (lmgrd)   into license usage data and to create
13:51:26 (lmgrd)   insightful reports on critical information like
13:51:26 (lmgrd)   license availability and usage. FLEXnet Manager
13:51:26 (lmgrd)   can be fully automated to run these reports on
13:51:26 (lmgrd)   schedule and can be used to track license
13:51:26 (lmgrd)   servers and usage across a heterogeneous
13:51:26 (lmgrd)   network of servers including Windows NT, Linux
13:51:26 (lmgrd)   and UNIX. Contact Macrovision at
13:51:26 (lmgrd)   www.macrovision.com for more details on how to
13:51:26 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
13:51:26 (lmgrd)   for your enterprise.
13:51:26 (lmgrd)
13:51:26 (lmgrd)
13:51:26 (lmgrd)
13:51:26 (lmgrd) The license server manager (lmgrd) running as root:
13:51:26 (lmgrd)        This is a potential security problem
13:51:26 (lmgrd)        and is not recommended.
[root@192 ~/cadence]$ 13:51:26 (lmgrd) Failed to open the TCP port number in the license.
[root@192 ~/cadence]$ lmstat -a -c license.txt
lmstat - Copyright (c) 1989-2007 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
Flexible License Manager status on Wed 12/30/2010 13:52
License server status: 5280@192.168.1.33
    License file(s) on 192.168.1.33: license.txt:
lmgrd is not running: Cannot connect to license server system. (-15,570:115 "Operation now in progress")
    Well, the problem is that it failed to open the TCP port in the license file (as the error said!). Without seeing your license file, hard to know, but my guess is that something on your system is blocking the usage of certain ports. The port is usually 5280 by default (on the SERVER line) - have you changed it? If so, maybe your system is set up to block usage of that port - or it's already in use?
    Anyway, I suggest you log a service request to http://support.cadence.com rather than relying on volunteers on a forum to get important things like your licensing working!
