  3. invoking virtuoso editor
  • Views 18782
MAAC
MAAC over 15 years ago
 i have installed the IC610 inside the folder /root/cadence/installs/IC610
Now iam trying to invoke the virtuoso editor..from the userguide i found the command
[B]icde &[/B]
 is used to invoke the tool..
i am trying the same as shown below:
[root@192 IC610]# icde &
[1] 3580
bash: icde: command not found
[1]+ Exit 127        icde
Can anyone help me on this?
Thnx....
    In IC6, the old individual workbench commands icde, icfb, icms, msfb, icds etc have been replaced with a common command "virtuoso". Initially the old names were kept as wrappers (with a warning) but in IC614 they have finally gone. In the documentation, every mention of icde seems to say that the commands have changed or gone - so I'm not sure which user guide you're looking at?
    Anyway, type "virtuoso" and you should be OK.
  • MAAC
    "virtuoso" should be typed from pointing IC610 folder or inside any subfolders..
    /root/cadence/installs/IC610/Installs is my installation path...
    You need to have <IC61instDir>/tools/bin and <IC61instDir>/tools/dfII/bin in your UNIX path. Not sure what you mean by saying '"virtuoso" should be typed from pointing IC610 folder or inside any subfolders'
