  3. How to edit/modify ansCdlPrintInstParams in .simrc file...
  • Views 3884
How to edit/modify ansCdlPrintInstParams in .simrc file for auCdl netlisting
Paulux
Paulux over 15 years ago
 May I know how to edit/modify variable "ansCdlPrintInstParams" in .simrc file such that the auCdl netlist is shown below?
.SUBCKT umim PLUS MINUS
CC0 PLUS MINUS 1.5e-4*cl*cw+2e-9*(cl+cw) $[CA]  $L=cl  $W=cw
.ENDS
XC1 out gnd! / umim cw=20 cl=20
Now my generated auCdl netlist is shown below. (But I want to move cl cw in the equation line after $[CA] to be $L=cl $W=cw and remove cl=15 cw=15!)
.SUBCKT umim PLUS MINUS cl=15 cw=15
CC0 PLUS MINUS 1.5e-4*cl*cw+2e-9*(cl+cw) cl cw $[CA]
.ENDS
Or if I use the wrong way, could you please help to recommend how to fix this?
Thank you very much in advance for your help and kindness.
***If I post to the improper forum, could you please kindly help to move to the proper forum and let me know when this message is posted?
The umim CDF is
 let( ( libId cellId cdfId )
    unless( cellId = ddGetObj( LIBRARY CELL )
        error( "Could not get cell %s." CELL )
    when( cdfId = cdfGetBaseCellCDF( cellId )
        cdfDeleteCDF( cdfId )
    cdfId  = cdfCreateBaseCellCDF( cellId )
    ;;; Parameters
    cdfCreateParam( cdfId
        ?name           "cl"
        ?prompt         "cl"
        ?defValue       "15"
        ?type           "string"
        ?parseAsCEL     "yes"
        ?name           "cw"
        ?prompt         "cw"
        ?defValue       "15"
        ?type           "string"
        ?parseAsCEL     "yes"
    ;;; Simulator Information
    cdfId->simInfo = list( nil )
    cdfId->simInfo->auCdl = '( nil
        dollarEqualParams nil
        dollarParams      nil
        modelName         ""
        propMapping       (nil cl cl cw cw)
        instParameters    (cl cw)
        namePrefix        "X"
        termOrder         ("PLUS" "MINUS")
        componentName     subcircuit
        netlistProcedure  ansCdlSubcktCall
 The mim1 CDF is shown below
    ;;; Parameters
        ?name           "l"
        ?prompt         "Length"
        ?defValue       "pPar(\"cl\")"
        ?type           "string"
        ?display        "t"
        ?parseAsCEL     "yes"
        ?name           "w"
        ?prompt         "Width"
        ?defValue       "pPar(\"cw\")"
        ?type           "string"
        ?display        "t"
        ?parseAsCEL     "yes"
        ?name           "c"
        ?prompt         "Capacitance"
        ?defValue       "1.5e-4*cl*cw+2e-6*(cl+cw)"
        ?type           "string"
        ?display        "artParameterInToolDisplay('c)"
        ?parseAsCEL     "yes"
        dollarEqualParams (cl cw)
        dollarParams      nil
        netlistProcedure  ansCdlHnlPrintInst
        instParameters    (C L W)
        componentName     cap
        termOrder         (PLUS MINUS)
        propMapping       (nil C c L l W w)
        namePrefix        "C"
        modelName         "CA"
 The .simrc is given as follows
auCdlCDFPinCntrl=t
CDLUsePortOrderForPinList = t
auCdlInstPrintOrder=list('instName 'connections 'instParams 'model)
procedure( ansCdlPrintConnections(fp connections )
        foreach( cn connections
            artFprintf( fp "%s " car(cn) )  ))
procedure( ansCdlPrintInstParams(fp pairList)
        foreach( pair pairList
                artFprintf( fp "%s " artMakeString(cadr(pair)) )
procedure( ansCdlPrintInstProps(fp pairList)
                artFprintf( fp "%s=%s " car(pair) artMakeString(cadr(pair)) )
procedure( ansCdlPrintModelName(fp isAPrimitive definedPropVal
                                  modelPropInstVal
                                  componentPropInstVal
                                  cdfModelName
                                  cdfComponentName
        when( isAPrimitive
            let( (model)
                model = nil
                if( definedPropVal
                    model  = definedPropVal
                if( !model && modelPropInstVal
                if( !model && cdfModelName
                    model = cdfModelName
                if( !model && componentPropInstVal
                    model = componentPropInstVal
                if( !model && cdfComponentName
                    model = cdfComponentName
                    artFprintf(fp "$[%s] " artMakeString( model ) )
