  3. Matlab RF/Spectre Toolbox
  • Views 4849
BoulderDash
BoulderDash over 15 years ago
 i'm working with Virtuoso 6.1.4 and ADE XL. I want to use Matlab scripts to process the data after simulation. I can add a Matlab script in the ADE XL results tab and it works fine (i can plot stuff, ..) but i can't use the function cds_srr to import the signals. The paths are correctly, Matlab find the cds_... functions.
If I execute cds_srr(....), the following error message occurs:
-> undefined function or method 'cds_innersrr' for input arguments of type char
 The function cds_innersrr.m doesnt exists in the directory, there is only a mex file.
I'm using Matlab 2010a.
Does anyone has an idea what to do?
Thanks alot!
 Ante
  • Tawna
    Tawna over 15 years ago
     Hi Ante,
    This is a known issue with Linux and MMSIM 10.1. It should work with MMSIM 7.2 (which does support R2010a and b).  Please contact Cadence Customer Support so we investigate this.
    Best regards,
    Tawna
    Hi Ante,
    In addition to what Tawna says, you also need to ensure that $LD_LIBRARY_PATH includes:
      setenv LD_LIBRARY_PATH `cds_root spectre`/tools/lib/64bit:$LD_LIBRARY_PATH
    If running on a 32-bit machine (or running 32 bit matlab), you'll need to miss out the 64bit part of the path.
    This is needed if you're running MMSIM72 or earlier. As Tawna said, the Spectre Toolbox in MMSIM101 doesn't currently work due to a compiler incompatibility with Matlab.
  • nevinalex1234
    nevinalex1234 over 13 years ago
     hi tawnaa, andrew
    Has this issue with MMSIM been resolved?
  • Ashish Patni
    Ashish Patni over 13 years ago
    Hi Nevinalex1234,
    Yes, this issue has been resolved. Please refer to the following COS Solution -
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11699006
    As far as your original post yesterday, as Andrew and others have mentioned many times, please mention which MMSIM version you are using and which Matlab Version you are using in that post.
    With Regards,
    Ashish
  • nevinalex1234
    Sorry for the trouble.
    I have updated my software specifications.
    I dont know what my hostid .
