  3. Ploting two graphs on wavescan using only 1 y-axis
  • Views 14683
r7aaex
r7aaex over 15 years ago
Hello, I have question regarding OCEAN "plot" command.  I have two vectors that I wish to plot on the same y-axis but the command defaults to two y-axis.  The question is how can force this to plot on a single y-axis?
 so far I have tried the following but both give all plots in two y-axis.
plot(Gain Phase)
plot(Gain Phase ?yNumber list(1 1) )
Thanks in advance,
Jorge
    Jorge,
    You need to ensure that the units attribute on the y-vector in the waveform object is consistent. See Solution 11265350
    You could achieve this by doing:
     drGetWaveformYVec(Phase)~>units=drGetWaveformYVec(Gain)~>units
     plot(Gain Phase)
    Although I'm not that sure it makes sense to plot phase and gain on the same axis, but that's up to you of course!
  • r7aaex
    Andrew, thanks for this, it gives both plots on the same graph.  The reason it is nice to have them together is to use the cursors to tell phase margin, gain margin easily.
    Thanks again!
    Jorge
