  3. Setting default selection for Virtuoso XStream Out
  • Views 16194
archive over 15 years ago
Hi All,
I am currently using IC6.14.510. I need help to set defaults for selections in the options of Virtuoso XStream Out and Stream In.
I need to set default for the following options:
1. Flatten PCells
2. Convert Arrays to Scalar Instances
3. Snap to Grid
Thank you in advance
Vijay
  • StefanSL
    StefanSL over 15 years ago
    Hi Vijay,
    a template-file should do everything you're asking for (and much more),
    have a look at the
    Design Data Translator’s Reference
    (transrefOA.pdf)
    section "Preparing a Template File and .cdsinit File for Stream Out".
    There you'll find an example of a template file and how to use it.
    Hope this helps
    kind regards
    Stefan
     Hi Stefan,
    Thank you for the help. I will look into this.
    Vijay
