  3. Parametric Analysis on Multiple Cores
  • Views 14914
AndrewMac
AndrewMac over 15 years ago
Is it possible to run a Parametric Analysis in Virtuoso Analog Design Environment with multiple analyses running in parallel on different cores?
 I'm currently using Spectre's multi-threading capabilities, but in a parametric sweep each analysis is independent so there could be a  much larger gain (up to 8X on an 8-core machine) running them at the same time on different cores.
