  3. Is there a viewer for Spectre pwl statements out there ...
  • Views 15876
Is there a viewer for Spectre pwl statements out there ?
baenisch
baenisch over 15 years ago
Hi all,
I"m currently doing so toplevel simulations and with help of a custom text based
pattern generator I managed to get all my signals in spectre pwl format that can
be included for Spectre or Ultrasim simulations
 Vclk_reset (clk_reset 0) vsource type=pwl wave=\[ 0 0 \\
  1.000000000000000e-05 0 1.000010000000000e-05 1.8 \\
  1.100000000000000e-05 1.8 1.100010000000000e-05 0 \\
  1.200000000000000e-05 0 1.200010000000000e-05 1.8 \\
  1.300000000000000e-05 1.8 1.300010000000000e-05 0 \\
Is there any tool out there that can give me a graphical output of my input stimuli ?
It's quite time consuming changing the pattern without knowing if one has defined the signals correctly :)
Best Regards
Andi
    Hi Andi,
    I wrote something years ago to do a preview for analogLib sources without running a simulation, but I don't know of anything which can do this for spectre sources from a netlist. To be honest, the simplest thing would just be to run a quick spectre transient on a netlist containing just the pwl source (from the command line) and then use viva or awd (depending on the version you're using) to look at the results. That would be very quick for such a simple circuit.
  • baenisch
    Hi Andrew
    I didn't think of that. Good idea
     Thanks a lot
    Best Regards
    Andi
