  3. optimizing
  • Subscribers 129
  • Views 14046
optimizing
martinmmuc
martinmmuc over 14 years ago
Is it possible for the circuit optimizer to
optimize Monte Carlo results?
I am just optimizing a latched comparator,
changing  W and L  and  try to minimize the
offset which comes out of  a 100 run Monte Carlo simulation
Thanks & Regards
Martin
  • Austin CAD Guy
    Austin CAD Guy over 14 years ago
     You may want to post this on the Custom Design forum.
    I'll move it...
    You didn't say which version you were using, but if using IC614, you can use ADE GXL. This has things like yield optimization which will allow you to optimize to maximize yield (so you'd set up a specification, i.e. a goal, on the offset, and it can then try to optimize the circuit so that it doesn't have failures during monte carlo due to the specifications not being met).
