  3. errors during LVS with RF Transistors @ IBM cms9flp pdk
  • Views 16769
jimito13
jimito13 over 15 years ago
Hello all,
I perform LVS with assura tool (IC6131-Assura 3.2) on my design that consists of nfet_rf & pfet_rf transistors (only this type and nothing else like capacitors,regular fets etc...) from IBM rf9flp library (part of cms9flp design kit) and i have a lot of errors concerning the sub! and VSS (ground) terminals.
I must note that i have removed the substrate and nwell contact rings around the transistors (nmos and pmos respectively) and i have created my own rings for the whole design.
It is very important to me for a fast solution and IBM's technical support team doesn't seem to cooperate for a solution...Let me be more specific with my problem.
I had created a simple test case with nfet_rf from rf9flp library that consists of a single nfet_rf and no subc in the schematic.In addition i removed the default guard ring of the nfet_rf.At the layout side i have the transistor and a subc component.This case passes VLDB LVS and according to IBM's team it is ok and they are working on a solution after my report to them.
Now,let's see the design.It consists of various nfet_rf (only this type of transistor and nothing else like capacitors,regular fets etc...).At the schematic side i use subc (same results if i don't use it since IBM admitted that it causes problem if it exists) and i have removed the default guard ring with substrate contacts of all fets because i create a custom one for all the nmos area in the layout.
Then i run VLDB LVS and i will show you the errors (rewires,nets) via the LVS.cls file below.If anymore info are needed for a conclusion i will provide them.
Thanks a lot in advance.I will appreciate any helpful feedback since it is very critical issue for me.
Best Regards,
Jimito13
****** ota_main_rf_2 schematic Dimitris_initial  <vs>  ota_main_rf_2 layout Dimitris_initial
Pre-expand Statistics
======================                          Original
Cell/Device                               schematic  layout
(lvtpfet_rf) Generic                              2       2
(pfet_rf) Generic                                13      13
(nfet_rf) Generic                                 9       9
(subc) Generic                                    1    1980*
Total                                            25    2004
Filter Statistics
=================                               Original            Filtered
Cell/Device                               schematic  layout   schematic  layout
(lvtpfet_rf) Generic                              2       2           2       2
(nfet_rf) Generic                                 9       9           9       9
(pfet_rf) Generic                                13      13          13      13
(subc) Generic                                    1    1980*          1    1980*
Reduce Statistics
=================                               Filtered             Reduced
(pfet_rf) Generic                                13      13           9       9
Match Statistics
================                                  Total             Unmatched
(lvtpfet_rf) Generic                              2       2           0       0
(nfet_rf) Generic                                 9       9           0       0
(pfet_rf) Generic                                 9       9           0       0
(subc) Generic                                    1       1           0       0
Total                                            21      21           0       0
Match Statistics for Nets                        22      30           1       9
================================================================[ota_main_rf_2]
====== Bad Initial Net Bindings (nets don't match) ============================
= = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = (badbind 1)
Schematic Net:  GND
S       1   of subc SUBCON
S       7   of nfet_rf S
Layout Net:  GND
L       1   of subc SUBCON
L      *1   of subc sub
L       7   of nfet_rf S
====== Unmatched Internal Nets ================================================
L ?avS8513
L ?avS8512
L ?avS8510
L ?avS8516
L ?avS8517
L ?avS8514
L ?avS8515
L ?avS8509
L ?avS8511
====== Suggested Terminal Rewire ==============================================
In the layout, terminal 'B' of instance avD20_7 probably should connect to net
avS8512 instead of net avS8515.
This makes a better match between layout net avS8512 and schematic net sub!.
In the layout, terminal 'B' of instance avD20_3 probably should connect to net
avS8512 instead of net avS8510.
In the layout, terminal 'B' of instance avD20_4 probably should connect to net
avS8512 instead of net avS8516.
In the layout, terminal 'B' of instance avD20_9 probably should connect to net
avS8512 instead of net avS8511.
In the layout, terminal 'B' of instance avD20_1 probably should connect to net
avS8512 instead of net avS8513.
In the layout, terminal 'B' of instance avD20_5 probably should connect to net
avS8512 instead of net avS8517.
In the layout, terminal 'B' of instance avD20_8 probably should connect to net
avS8512 instead of net avS8509.
In the layout, terminal 'B' of instance avD20_6 probably should connect to net
avS8512 instead of net avS8514.
In the layout, terminal 'sub' of instance avD226_1 probably should connect to
net avS8512 instead of net GND.
====== Problem Schematic Nets (no exact match in layout) ======================
S
S ?GND
S       1   of subc SUBCON
S       7   of nfet_rf S
S
S ?sub!
S       1   of subc sub
S       9   of nfet_rf B
====== Problem Layout Nets (no exact match in schematic) ======================
L
L ?avS8513 ?avS8512 ?avS8510 ?avS8516 ?avS8517 ?avS8514 ?avS8515 ?avS8509
L ?avS8511
L (total 9) with:
L       1   of nfet_rf B
L
L ?GND
L       1   of subc SUBCON
L       1   of subc sub
L       7   of nfet_rf S
====== Summary of Errors ======================================================
Schematic  Layout     Error Type
 1          1         Bad Initial Net Bindings
 -          9         Suggested Terminal Rewire
 -          9         Unmatched Internal Nets
  • tkhan
    tkhan over 15 years ago
    If you have access to it read the 8RF training guide, it explains the substrate methodology quite well. I can answer your question but not sure about NDA violation on my part due to the details required to answer. You should contact the foundry or fab provider (i.e. MOSIS) in this case.
  • jimito13
    At first thanks for the feedback. Where should i find the 8RF training guide?Is it located at the pdk installation?In addition,what are the NDA violations you mentioned?If you can answer my question please give me some more advice.
    Thanks in advance,
    Jimito13
  • tkhan
    8RF = IBM 130nm kit, find on document server where you obtain your pdks. Depending on how much process-related info I give in a public forum I could violate my Non-Disclosure Agreement.
  • jimito13
    Hi tkhan,
    We worked on a solution with our CAD manager according to pdk's (cms9flp) manual.Now,i can pass a clear LVS.In addition,i downloaded the appropriate section of the file you suggested me and i will try to match the guide with the solution we found for our current technology.Ok,i understand the limitations and i will not ask you for more info ;-) In any case,thank you very much for your feedback and the helpful suggestion.
    Best Regards,
    Jimito13
