  3. rangecnst_severity_level
  • Subscribers 129
  • Views 14445
frogconsultant
frogconsultant over 14 years ago
Hi All,
First I apologize if it is not the correct forum for analog mixed-signal questions.
I am relatively new in AMS environment and I am having an issue while I am implemented a RTL code with the analog circuit to run AMS simulator. The netlisting and compiling part are successfull but during the elaboring part, the simulation stops with the following message:
Error! range constraint violation
Set "rangecnst_severity_level" ncsim tcl variable to ignore this error.
Does someone know where to put this variable and how to do it?
Best regards,
    If using ADE in IC614, then go to Simulation->Options->AMS Simulator, and go the Miscellaneous tab. There's an etry labelled "Probe Tcl file" and you can specify a path to a tcl file. In this tcl file, put:
    set rangecnst_severity_level warning
    (there's more info on the meaning of the variable if you search in cdnshelp for the Incisive release for the variable name).
  • frogconsultant
    Thanks Andrew for your feedback. It works also when I am typing in the ncsim window before to run it but the file will help me not to type each time.
