  3. SPICE netlist viewer?
  • Views 18080
RoboHorse
RoboHorse over 15 years ago
I am looking to for a schemetic generator (or a GUI based circuit generator that draws out conenctions to blocks) from a given SPICE netlist.
I found something very close here offered by concept engineering: www.concept.de/sv_index.html
Does  Cadence offer anything like this?
HA
  • skillUser
    skillUser over 15 years ago
    Hi HA,
    Yes, in the IC6.1.x releases this is the "Spice In" capability.  In IC5141 there is only CDL In and this is not really flexible enough to handle Spice since it was designed for the CDL syntax not for Spice.  Your best bet is to use IC61x and access File -> Import -> Spice which will read CDL, Spice, HSpice and Spectre syntax for the input netlist and generate a schematic from that.
    Lawrence.
