  3. modifying the connectivity in Technology file without effecting...
  • Views 14467
modifying the connectivity in Technology file without effecting the existing VIA layers
sandroji
sandroji over 15 years ago
Dear Andrew,
I have a tech file with the following layer stack,
MET6,VIA5,MIM,MET5,VIA4,MET4,VIA3,MET3.
std vias are defined as :
MET6/VIA5/MET5
MET5/VIA4/MET4
MET4/VIA3/MET3
When placing a MIM capacitor in the layout and applying marknet to a net which contains one of the MIM cap terminals , i get a short thought the MIM Capacitor.
Is there a way to redefine the connectivity without using STOP layers (on the input layers i mean)? , in order to prevent this false short from effecting the markNet result.
 I dont want to replace any layers in the tech file or do any change which might effect existing designs.
 Thank you for your support and great source of information
Alex
