  3. Ploting from transient simulation using strobeperiod op...
  • Views 16290
Ploting from transient simulation using strobeperiod option
NombrePantalla
NombrePantalla over 15 years ago
Hello.I am running a very long transient simulation (several dais of simulation). To reduce the size of the simulation results data, I am using the strobeperiod option. I want to plot some waveforms before the simulation finish but the simulation data are not available until the simulation finish.
Is there a way to plot these data before spectre finish the simulation?
Is thera a way to force spectre to write the simulation data to the hard disk every a fixed time or to force it with some command in the icfb command line?Thanks in advance Guillermo
    Guillermo,
    It should flush the data regardless, on a fairly regular basis. There are options in the transient options - flushpoints, flushtime, flushofftime.
    However, it's unusual to have to set these. Which version of the IC environment and simulator are you using?
  • NombrePantalla
    First of all thank you very much for your interest. We are using the 5.10.41_USR1.7.43 release. I have reviewed the documentation and you are right, I will try it the next time.
    Thank you very much again
    Best regards
    Guillermo
