  3. ADE-L state to be loaded in ADE-XL
  • Views 16075
frogconsultant
frogconsultant over 15 years ago
Dear All,
I have developped some test benches using ADE-L option under OA 6.1.4 which looks similar to 5.1.41. Now I want to use the states of these test benches under ADE-XL to benefit from the other options available in OA.
I am having difficulty to load the state from ADE-L into ADE-XL environment. It may be obvious but could someone tell if it is possible first and how to do it if it is possible to do the transfer?
Thanks in advance,
Fabian
  • Marc Heise
    Marc Heise over 15 years ago
     in the ADEXL view you first need to add your "Test"  (the simulation schematic) to your setup.
    This is done in the Data View  Assistant  (usually on the left side). After that you can right
    click on that test and in the context pop-up is an option to load the state.
    Marc
