  3. Monte Carlo simulation under ADE XL
  • Views 16657
chihai2011
chihai2011 over 15 years ago
 Hi, guys
 Revently when I was working on Monte Carlo simulation with ADE XL, there is an error happening all the time .
\o *Error*   Error ID  = 5011
\o *Error*   Error Msg = Simulator failed to complete the simulation.
\o
\o           Error found by spectre during hierarchy flattening.
\o ERROR
\o           (SFE-1997): "input.scs" 25: mc1: parameter `dut': A scalar
\o           is expected as the value for parameter `dut'.
It also says there is not statistical data generated.
Could you please help me on this?  Thank you so much!!!!!
  • Quek
    Quek over 15 years ago
    Hi chihai2011
    Are you able to run a normal spectre simulation? Would you please enter the following in ciw and let us know the output?
    getShellEnvVar("CDS_NETLISTING_MODE")
    Please also provide the following information:
    linux>virtuoso -W
    linux>spectre -W
    Best regards
    Quek
    Hi Quek,
    That should be "CDS_Netlisting_Mode" (the case is wrong). Simpler to use the SKILL function:
    cdsGetNetlistMode()
    Anyway, I suspect the issue is due to a version of spectre being used which is too old. Originally the "dut" (Device Under Test" had to be a single instance, but that changed in MMSIM70 Update 1 (7.0.1.053). If using a spectre version before that, and specifying the Device Under Test in the Monte carlo options form in ADE XL, then I suspect you could get this problem.
  • Quek
    Thanks Andrew. : )
