  3. Can no plot signals during Monte-Carlo tran simulation
  • Views 18517
Ozgur
Ozgur over 15 years ago
I can not plot signals during Monte-Carlo analysis run in Virtuoso 6.1.3. After simulation completes simulation results appear in Results Browser. Is there any solution to see signals during simulation?
Best Regards,
Ozgur
    Ozgur,
    Your question is not that clear. What exactly are you trying to do?
  • Ozgur
    Dear Andrew,
     I want to be able plot transient simulation results while Monte Carlo simulation is still running. In IC 5.1.41 I can plot transient results up to the completed point when doing Monte Carlo simulation, however in IC 6.1.3 ADEXL I can plot monte carlo simulation results only after simulation is completed. During simulation running it does not show the results up to the current time point.
    I hope my problem is clear now.
     Best Regards,
    Ozgur
  • pbssj
    pbssj over 14 years ago
    We have a designer complaining about the same issue. Is there any soln or workaround for this issue ?
    Pranav
  • pbssj
    FYI -  We using 615.isr9, 64-bit.
    Please contact customer support for this issue.
  • Tshun Kiat
    Tshun Kiat over 11 years ago
    Hi, Does anyone know whether this had been fixed? I'm running IC616-ISR6. Regards, -- TTK
