  3. Check signal value in order to stop simulation
  • Views 16931
frogconsultant
frogconsultant over 15 years ago
Hi Everyone,
I am trying to optimize the simulation time but checking the value of an analog signal in the simulation.
I am wondering if there is already a block (veriloga) or a function under cadence which check the value of an analog signal (i.e. for example after 10 values with 1us apart under 5% of the final value) and stop when the condition is met.
Any articles, websites or veriloga model would be perfect.
Thanks in advance for your help,
  • Marc Heise
    Marc Heise over 15 years ago
    there is a solution on support.cadence.com about this. Search for:  11268710
    Basically you have to:
    1. Write a MDL script with the stop condition   (search for "autostop" in the documentation)
    2. Enable autostop in ADE  (in the tran options)
    3. Add the the MDL script execution as a  commandline option
    Marc
    Also, in IC614, you can reference an MDL script directly in ADE - see Solution 11685686
    Another approach would be to use a VerilogA model, and use $finish to end the simulation when the condition has been met.
    Best Regards,
  • frogconsultant
    Dear Marc and Andrew,
    Unfortunately, I can not access the solutions you provide me as I am just member of the community and not having a login account for the sourcelink solution. If you do mind putting the solution in this topic it would be great.
    Since this morning, I am looking on the veriloga path with $abstime, timer and $finish statements.
    Thanks, Fabian
     Hi Fabian,
    The solution I referred to is describing the new Simulation->MDL Control menu which allows you to reference an MDL script to run the simulation. It's important to use this:
    envSetVal("spectre.envOpts" "mdlSimExecName" 'string "/export/home/apps/MMSIM101_isr/tools/bin/spectremdl")
    If using IC614, because otherwise it doesn't work (this is fixed in IC615). Of course, alter the path as necessary.
    For more details on SpectreMDL, read the documentation on SpectreMDL (in the MMSIM documentation) which covers how to use autostop.
