  3. How to find a pin in the layout using SKILL....?
  • Views 18804
Amit  Biswas
Amit Biswas over 15 years ago
I am using the following command to search the pin called "b"  in the layout
leSearchHierarchy(cv cv~>bBox 0 "pin" list(list("term name" "==" "b")))
But the output I am getting is for "*b*" not for "b"
Any  comment , suggestion will be  deeply appriciated
Amit
  • skillUser
    skillUser over 15 years ago
     Hi Amit,
    I believe that the GUI form implicitly adds a "^" to the front and a "$" to the end of the query, but your SKILL code criteria is taken more literally, hence it would find all of the pins that had a "b" in the name.  The simple fix in this case is to change the search expression to "^b$" and you will get just the pins with the name "b".  I tested this in IC5141 and IC61x and it seems that the leSearchHierarchy() function behaves the same in both.
    Best regards,
    Lawrence.
  • Amit  Biswas
    Thank you Lawrence. Its working fine.
  • Amit  Biswas
    Thanks Lawrence , It is working.
    But One problrm is using SKILL command  is very slow compared to GUI, Is there any way to make it faster ?
    Amit
  • skillUser
    Hi Amit,
    The GUI uses a different function - leHiSearch() does not call leSearchHierarchy() directly, and if looking within the current cellview, it calls a different function still. So, the answer is either to try and write your own pin search routine (rather than the generic capabilities of the leSearchHierarchy function), or to perhaps invoke the GUI function instead.
    Lawrence.
