  3. ADE window Freezes in IC5.141USR5
  • Subscribers 132
  • Views 16353
behrooz
behrooz over 15 years ago
Hello Everyone,
 After a couple of days of problem in running LVS and RCX for a previously created layout using  IBM_PDK, CMRF8SFDM, and design kit V1.4.0.7DM, and a posting in here, and some clues, now I got a new bigger problem. and that is:
When i open a schematic, and try to open ADE, Cadence hangs, and I can't do any other thing. I'm using IC5.141USR5, and I should say that I can open the any layout, created new library, add instances, but whenever I try to run ADE, it freezes, no matter what design kit version I'm using. Even I tried to change the cadence version from USR5 to newer ISR, but not outcome. .cdsevn and .cdsinit, display.drf, .simrc files come from the design kit directory without any changes. The ic5.151USR5 folder is Ok on the server, as I see other people can run Cadence without any problem. I have attached CDS.Log file to this post. Any suggesstion is highly appreciated as I'm really in a big trouble with lots of coming deadlines.
Regards
Behrooz Nakhkoob
CDS_LOG.zip
    Please use customer support - http://support.cadence.com - for urgent issues. That way you have access to Cadence's customer support organisation, rather than relying on your fellow community members who may not have time to debug this.
    Hanging sounds very odd, though.
  • behrooz
    Hello Andrew,
    Thanks for reply.
    I'll send a request to support.cadence.com. But before it, I know that when ADE wants to be loaded , other than "Simui.cxt" and "awv.cxt", 4 other files need to be loaded. They are:
    "spectrei.cxt",  "spectrein1.cxt", "ultrasim.cxt",  "Amc.cxt". When I look at the CDS.log, I see that just, the first two files "simui.cxt", and "awv.cxt" have been loaded and it cadence freezes without loading the other 4 files. Does it give any clue?
     Regards
    Behrooz
  • likelike
    likelike over 13 years ago
     I have got similar problems , but is with IC614. when I invoke the ADE, it is fine, but when close it... Everything freeze.
    Do you got any solution to your problems?
