  3. regarding simultion convergence issues
  • Views 17288
fazul
fazul over 15 years ago
Hi everybody!
i have a question regarding  simulation convergence.. I am running a Transient Noise Analysis
with errpreset = conservative. Initially it was having difficultly in converging so i tried the usual techniques
like relaxing abstol, reltol, increasing maxiter, method=gear2only as it was mentioned in the manuals.
Now the simulation seems to run to completion without errors but with a large number of warnings and notices from spectre.
WARNING : The bulk-source junction current exceeds `imelt'. The results computed by Virtuoso(R) Spectre are now incorrect because the junction current model has been linearized
WARNING :Vgd has exceeded the oxide breakdown voltage of `vbox'
WARNING : Minimum time step used.  Solution might be in error.
spectre completes with 0 errors, 4672 warnings, and 2409 notices
my question is how reliable is the simulation result in this case. At a glance the result seems to be correct but can i really ignore all these warnings and trust the result?
what is the general approach that a CAD engineer takes when he is faced with these kind of warning?
Forgive me if my question is not clear, i am quite new to simulation and havent completely understood  how  spectre/spice simulators work . So any pointers will be very helpful...
Thanks a lot, have a nice day.
Fazul
  • Zach
    Zach over 15 years ago
    I will defer your questions to others and instead ask two of my own.  1) Are you running 64-bit Spectre?  I've seen issues with convergence and 32-bit.  2) It sounds like you have an IBM PDK.  Are you running the supported version of Spectre?
  • fazul
    hello Zach,
    Yes i was running on 64bit Spectre +aps  ..(MMSIM7.2ISR2) ...
     however i am not using IBM PDK.instead its in-house pdk.
    i can understand that there will be some effect on convergence based on what binary i choose to run the simulation
    but   which one do you think is  recommended (32bit or 64bit binary)  when doing simulation with convergence issues?
    my simple understanding is that,
    * when the simulating circuit size is of large use 64bit binary, (accuracy is better, 32bit becomes slower)
    * when trying to plot waveforms of large data size use 64 bit binary
    but what about  from a simulation convergence point of view?
    Any advice ? Sorry this sounds like a new different question .
    thanks Zach for replying.
    Fazul
    Fazul,
    Switching between 32 and 64 bit would not be the first thing I'd try to resolve convergence issues. It's possible you may get a different result due to slight alternation of the numerical processes, but that should normally only be in the case of marginal convergence (or non-convergence).
