  3. Remove Backannotate
  • Views 14839
Remove Backannotate
Trail Animal
Trail Animal over 15 years ago
 In my GXL window, I mistakenly right-clicked and selected backannote.  Now, eveytime I try to run a simulation, a new design variable gets created (corModelSPec) with value: File=All#Global#allModels.scs Section="tt";File=All#Global#design.scs Section=;File=All#Global#wafer.scs Section=;
 This causes an error which halts simulation.  I try to delete this variable, but it gets auto-created.  How can I get rid of this???
    This looks like the same issue as in CCR 817025 which was fixed in IC6.1.5. However, I would suggest contacting customer support - so they can look at your data and advise as to how it can be worked around if you're using an earlier version.
    Best Regards,
