  3. No output was requested. (However, saving signal `vddd!...
  • Views 6037
No output was requested. (However, saving signal `vddd!'.)
naderi
naderi over 15 years ago
 Hello all,
 I am using spectre (IC5141) alone to simulate a netlist. In order to save disk space I put  "saveOptions options save=none" in the netlist and capture the required data by verilogA. However, simulator still record the transient signal of a node and warn this behaviour in the log file as following.
Is there any way to stop spectre of recoding the useless signal?
Ali
    saveOptions options save=nooutput
    should do this. Note however that this completely disables any saving - so you can then turn it back on in particular analyses. The reason why "none" outputs a single signal is historical - due to the way the results output is architected - and saving a single arbitrary signal was a workaround because of the architectural limitatio.
