  3. Parse instance brackets in Ocean
  • Views 15491
BVT1
BVT1 over 15 years ago
Hello there,
I am trying to save/print the vth of a MOS in instance DIODE<0> using Ocean. The pointy brackets do not seem to work with Ocean. I tried one backslash, two backslashes and none in front of each bracket. The latter option seems to be going through okay (i.e. Ocean doesn't complain), but the result is nil.
 This is what I've tried with no success:
"VDSAT_MD"  "DC"  "OP(\"BIAS_MIR.DIODE\<0\>.MMIR0.mds\" \"vth\")
"VDSAT_MD"  "DC"  "OP(\"BIAS_MIR.DIODE\\<0\\>.MMIR0.mds\" \"vth\")
"VDSAT_MD"  "DC"  "OP(\"BIAS_MIR.DIODE<0>.MMIR0.mds\" \"vth\")
 Any help will be much appreciated.
 Thank you
  • skillUser
    skillUser over 15 years ago
     Hi BVT1,
    It looks like you are using "." as the hierarchy separator, but I believe the default is usually "/" - what does "outputs" return for the names also? I have a feeling that the last name syntax may be correct (using the angle brackets with no escaping), but the hierarchy portion after it is not.
    Hope this helps!
    Lawrence.
  • BVT1
    Hi Lawrence,
    I just cracked it!
    The DC Operating Point results in ADE give you the following expression for a MOS parameter:
    OP("BIAS_MIR.DIODE\\<0\\>.MMIR0.mds" "vth")
    Since we need to escape both " and \ in the expression above for Ocean to parse it with no errors, and given that the above expression uses double \, I escaped each of the " and \ above resulting in the following working expression:
    OP(\"BIAS_MIR.DIODE\\\\<0\\\\>.MMIR0.mds\" \"vth\")
    I hope it makes sense and helps others with similar issues.
    BVT1
  • skillUser
    Hi BVT1,
    good news, glad to hear it!  I must be missing the surrounding context, but it looks like you have a string within a string, or have something that may be parsed more than once - for that sort of scenario you may well need to do the double escape,"\\" or even "\\\\" as you needed to do.
    Anyway, happy that you got things working (despite my attempt to help ;-) )
    Lawrence.
