  3. Cadence manuel
  • Views 15071
Cadence manuel
mozdas
mozdas over 15 years ago
Can anybody tell me where I can find a cadence manual. ?
  • Marc Heise
    Marc Heise over 15 years ago
    I assume that by "Cadence" you mean the Virtuoso IC product family?
    (following is also valid for MMSIM and IUS installations)
    The documentation system can be started pre 6.1.4 with "cdsdoc", 6.1.4 and
    newer with "cdnshelp" or by pressing one of the many "Help" buttons.
    The documentation files ( html + pdf ) can be found in:
    <your_software_install_path>/doc
    Marc
  • mozdas
    Thank you Mr. Marc I need a manual for  cadance analogue  circuit design simulations how to make an ac analysis and see the output graph for example. This link may show an example.
    Regards
    Mehmet
  • skillUser
    skillUser over 15 years ago
    Hi Mehmet,
    Also the documentation is available in COS (Cadence Online Support) in addition to many helpful solutions, videos on how to use the tools, Design Tasks for flow oriented problems and tasks and more in-depth Application Notes.When you search for keywords or a simple phrase you can get some good results, e.g. "How to do an ac simulation" will return a few solutions and a few matches in the documentation too.
    Try it, you might like it!
    Lawrence.
