  3. Regarding behavioural modelling of analog design
  • Views 15142
Analog Design
Analog Design over 15 years ago
     I have a dout wheather we can retrive back the exact circuit (Schematic) from behavioural modelling of analog Block(designed using verilog-A). Because whatever the behavioural design  we do in digital using verilog , we able to get RTL veiw of our design . Is it possible in case of analog Block modelling?
    Even with digital, you normally can't go from behavioural to RTL. You can write RTL and synthesize gates from it. There are some tools (like CtoS) which can synthesize from C, but in general you can't synthesize arbitrary digital behavioural models.
    Synthesis from Analog Models is not something that is really available (there have been some forays into Analog Synthesis for specific types of design, but nothing general, and nothing that has been particularly successful).
  • Analog Design
    thanks for your clarification .
    > successful).
    > Regards,
    > Andrew.
    > View this message online at:
    > http://www.cadence.com/Community/forums/p/18330/1260914.aspx#1260914
    > You received this email because you subscribed to notifications for the
    > Custom IC Design Forum. To unsubscribe, log in, go to forums, and change
    > your forum subscriptions.
    > http://staging2.cadence.com/community/forums/ForumSubscriptions.aspx
