  3. About function define
  • Views 18268
bobbygang
bobbygang over 15 years ago
Hi, I wrote function define code like this :
procedure(MMM(A B C D E)
                   setplist(A '(B D C E))
                   F=getqq(A B)
                   F
I want to achieve that when I input :    MMM(bobby xx (1 2 ) yy (3 4))
it will give me the result :        (1 2)
But it always tell me          *Error* eval : unbound variable  -bobby
Does it mean that when I use the function MMM I should define symbol "bobby" "xx" "yy" first?
I think it's too cumbersome. How to solve this problem ?
  • skillUser
    skillUser over 15 years ago
     Hi Bobby,
    I can't quite figure out what you are trying to do. In this case you appear to be calling the procedure incorrectly, you would need to do something like this instead:
    MMM('bobby 'xx '(1 2) 'yy '(3 4))  (you could call "list(1 2)" instead of '(1 2) also).
    But even then the code probably wouldn't work.  If you call MMM with just "bobby" the SKILL interpreter will look for a variable (or function) that matches the symbol bobby and it is not finding one.  If you make the procedure an nprocedure then it might start to work the way you might want it to,  something like
    nprocedure(MMM(args)
      let( (h)
        when(h=car(args)
          setplist(h cdr(args))
          F=getqq(h cadr(args))
        ); when
      ); let
    ); nprocedure
    MMM(bobby xx (1 2) yy (3 4))
    => (1 2)
    bobby.xx
    => (1 2)
    bobby.yy
    => (3 4)
    F
    => (1 2)
    Is this what you are looking for?
    Lawrence.
    nprocedures are not the right way to do this really because usually they rely on runtime evaluation - in this case they don't, but nprocedures don't generally work properly in SKILL++ code (in this case it does work, but you still get a warning). BTW, there's a typo in Lawrence's code anyway - the getqq should be a get (no "q" at all) otherwise it doesn't work.
    Assuming you didn't really want a global variable F in the code, I  would do this as a macro (which is the right way to do this):
     defmacro(MMM (A B C D E)
        setplist(',A '(,B ,C ,D ,E))
        getqq(,A ,B)
    (be careful about the quotes here - the one  before the open curly bracket is a backquote; this allows selective evaluation within the macro). Macros are evaluated at "compile" time - so they will be expanded in place.
    If you really want the variable F to be assigned, just put F= before the getqq in the macro.
  • skillUser
    Oops, good catch, thank you - I tested it with "get" but I didn't copy & paste the code hence the creeping in of mistakes.
    I like the macro approach, it makes more sense even if the code looks strange.
    Lawrence.
  • bobbygang
    It works! Thank you very much.
    Moreover some of your discussion is diffculty to me. It seems I need more time to become familiar with function define command.  What is the difference between defmarco and procedure?
    Bobbygang.
    Hi Bobbygang,
    A function defined  with procedure() will be a standard "lambda" function, for which all the arguments are evaluated before the function is called. Most functions are of this type in SKILL.
    A function defined with nprocedure() is an "nlambda" function. These do not have any of their arguments evaluated before the function is called - and as such receive all the arguments raw in a list. The function itself is then responsible for evaluating those it wishes to evaluate. The downside of such functions is that they tend to rely on run-time evaluation, which means less advantage can be taken of byte-code compilation, and so can be less efficient.
    A macro defined with defmacro() is run at compile time - essentially the body of the defmacro is not supposed to actually do the action, but instead to produce the code needed to do the job. Since it sees the arguments raw, it can build SKILL code which has the same kind of semantics as a built-in function would - no need to quote things. The result of the defmacro is SKILL code, which can then in turn be byte-code compiled and so sees the same speed benefits that normal code does and it doesn't do any run time evaluation. See Understanding SKILL macros on Cadence Online Support.
  • bobbygang
    I think I understand what you mean. I will see the reference for detailed imformation. Thank you !
    Bobbygang
