  3. Simulation with MATLAB generated data file as input to Anagol...
  • Views 15760
Simulation with MATLAB generated data file as input to Anagol block
Analog Design
Analog Design over 15 years ago
Hi ,
    I wan to give MATLAB generated data file as input source to analog circuit for simulation in cadence spectre . How to do it ?
    If you can get matlab to write out in an ASCII file with two columns, time and voltage/current, you can then use a vsource from analogLib, and  choose the type as "pwl" and then select to read the data from a file.
  • Analog Design
     Hi .........,
    Is it accept .txt or .csv  format  ?
    "spectre  -h vsource" will tell you what format it is expecting it in. The file suffix is irrelevant.
