  3. RULE LEF_DEFAULT definition for Abstract Generator/Encounter...
  • Replies 8
  • Subscribers 136
  • Views 4056
RULE LEF_DEFAULT definition for Abstract Generator/Encounter/NanoRoute
eklikeroomys
eklikeroomys over 15 years ago
I am using Cadence Abstract Generator to create abstract cell views for a standard cell library. In the Verify Step, I keep getting the following error: Encounter: (NRDB-158) There is no default via from LAYER MET1 to LAYER MET2 in RULE LEF_DEFAULT. I do not know how or where to define this RULE LEF_DEFAULT, please help.
  • eklikeroomys
    I cant find this RULE LEF_DEFAULT in the technology file
  • Alex Soyer
    Alex Soyer over 15 years ago
     Please look at the LEFDefaultRouteSpec constraint group in you technology file (that you could dump with the technology toolbox).
    All custom vias which are part of the validVia list of the LEFDefaultRouteSpec constraint group will be considered as DEFAULT.
    Alex
  • eklikeroomys
     Halo alex,
    This is an old post which has been solved already, I dont know how to remove it,
    thank you
  • Sohaib Qazi
    Sohaib Qazi over 14 years ago
    Hi eklikeroomys,
     I you have resolved this issue, can you please tell me how can I resolve it as I am stuck in same error i.e. There is no default via from LAYER MET1  to LAYER MET2.
    Qazi
  • stevemc
    stevemc over 14 years ago
    I'm not finding this to be the case. My techfile has
       ( "LEFDefaultRouteSpec" nil "LEFDefaultRouteSpec"
        interconnect(
            ( validLayers
                ( M1 M2 M3 M4 M5 M6 M7 )
            ( validVias
                ( M2_M1 M3_M2 M4_M3 M5_M4 M6_M5 M7_M6 )
        ) ;interconnect
    and I'm still getting the error during globalDetailRoute
     #ERROR (NRDB-158) There is no default via from LAYER M1 to LAYER M2 in RULE LEF_DEFAULT.
    btw, I'm running Encounter 11.10
  • RobB47
    RobB47 over 7 years ago in reply to stevemc
    I'm having a similar issue when using nanoRoute.
    When I dump my technology file, the via definitions appear to be there.  Additionally, when I place the design I can see that the tool is able to drop in the correct vias.
    I've tried creating a non default route spec, but even if I assign all nets to that NDR the tool still fails on error NRDB-158 during routing.
    Ideas on how to fix this?
    Andrew Beckett over 7 years ago in reply to RobB47
    The Forum Guidelines ask you not to post questions in old threads - and in this case it may be better answered elsewhere. So I'd suggest you ask the question in the Digital Implementation forum, which would be more suited for NanoRoute and Innovus questions.
  • RobB47
    RobB47 over 7 years ago in reply to Andrew Beckett
    Thank you Andrew, I will repost as a new question.
