  3. Plot command failed
  • Views 14577
Plot command failed
Renee
Renee over 15 years ago
I had some problems with plotting when I run DC parametric sweep. It reports that:
Warning: <COM.cadence.awd.graph.GraphManager@5585dc> Plot command failed, cannot find signal:"IO:1"
The simulation is successful, but I cannot see the plot.
I do not know how to solve this problem.
PS. The icfb version is IC 5.1.41.169 and the linux is red hat 9.
Thanks in advance
Lei
    Lei,
    This suggests that the current through terminal one of that component has not been saved. Look in the results browser, is it there?
    Note that the specific version you are using is 6.5 years old (that's the base IC5141 version); that's not really wise after all these years (although that's probably not the problem here).
