  3. "freeing" nets in 6.1.x VXL
  • Replies 12
  • Subscribers 133
  • Views 6786
linbo
linbo over 15 years ago
 Does anyone have any hints for "freeing" shapes and vias from their net connectivity in VXL 6.1.x?  It seems the sticky net problem from a long time ago is back.
Example:
 I have a via on a net named foo with an error marker.  If I query the via the net is vdd.  When I extract, the error marker remains and the error shape is still there and the via's net is still vdd.  Despite quitting out of Cadence session and restarting the dang via remains firmly connected to vdd.  It is clear that vdd is not involved in any way with the via or the net.
 The only way I can get the via to "free" it's net assignment is to copy the via to a second via, delete the first one and place the new copy onto the net named foo.   If I re-extract the net on the via is now foo.
If someone has some skill code out there that could fix this I would really appreciate it.  If you work for a company that wants the layouts to be "XL compliant" this is a real pain.
  • sPoK
    sPoK over 13 years ago
    Hi Alex,
    I've tried everything you suggested but none worked out.
    It would be easy to fix this with "Select-> All shapes on net" and then change the connectivity, but this is not working also, no single shape selected. (there is a limit set for this function, 20k shapes, and I have around 10k).
    Or some skill code to convert paths to wires, then, I suppose, the extraction should work ok.
    Srdjan
  • Alex Soyer
    Alex Soyer over 13 years ago
    I'm sorry to hear that.
    You have around 10k objects but it could be much more than 20k shapes as a via contains at least 3 shapes.
    You could increase the maximum number of shapes to be selected by using this virtuoso environment variable:
    graphic maxFigNetSelectionLimit int 20000
    Same as the previous envVar please make sure to restart Virtuoso.
    Alex
