  3. Strange behavior on unity prefixes.
  • Views 15479
Taimur
Taimur over 15 years ago
Hello. I am facing really strange issues with Cadence Virtuoso 6.1.4. Sometimes, when I put units like atto, femto, pico, nano, etc, in parameters, the software translates it to e118, e115, e112, etc. It should be e-18, e-15, e-12, and not the 118, 115, 112!!!!!!!!!!!!!! It happens with more than one design kit, so I'm sure it is an issue with the software, and not the DK. When netlisting for spectre simulation, the netlister put these unreasonable values to the simulator. Did some of you face this problem before???
  • Marc Heise
    Marc Heise over 15 years ago
    which OS are you running the software on? You might want to check with:
    prompt> <IC614_Install_dir>/tools/bin/checkSysConf  IC6.1.4
     I think I saw things like that happen with non-Red Hat installations.
    Kind regards,
    Marc
     PS:Your keys with the exlcamation and question mark seem to be broken.
    One customer was seeing something recently when using RHEL 6 ; they moved back to RHEL 5 and the problem went away.
    We do not yet support RHEL 6 (see http://www.cadence.com/rl/Resources/release_info/Supported_Platforms_Matrix.pdf ). New Base releases (i.e. not existing releases) will add support for RHEL 6 from this year onwards.
    Usually however such problems are either something that is a fault with the OS (and needs a patch), or needs some adjustment of the software to cope with something - that's the kind of thing that will happen as development to support a new OS happens.
  • Taimur
    Hello. This is exactly the case. I am (was) using RHEL6. Thank you so much.
