  3. Reading input/data file
  • Views 5357
EveBell
EveBell over 15 years ago
Hi!
I've built a 32 bit floating point adder schematic and I'd like to read different floating point numbers (around 100  32 bit words where each bit is vdc=1 or 0)  in during a simulation. What is the best way to accomplish it?
Any insight will be helpful.
Thank you!
    You didn't say which simulator you're using, or which version. If spectre then you can specify digital inputs using a vector file (see "spectre -h vector"), which in IC61 is available under Setup->Simulation Files. In IC5141 you'd have to do it via an include file, which then does a vector include.
  • EveBell
    Thank you Andrew! I'm using IC5141. Please excuse me, but I'm very new to Cadence.Therefore some of my question my seem very fundamental, but I really need some input. When you say see"spectre -h vector" where do I do that? Also, how do I use an include file? Should I create a data file in Cadence that include my numbers? If so, what language do I use? Or can I import from a data file that is not in Cadence? And if so, how do I do that? Again, thank you!
    You would type "spectre -h vector" in a UNIX terminal. Alternatively look at the documentation in cdsdoc.
    If you want to have an include file, you'd create a file called (say) incvector.scs with the contents:
    vec_include "vector_filename"
    The details of the vector file itself are covered in more detail in (I think) the Ultrasim User Guide (check <MMSIMinstDir>/doc/UltraSim_User/UltraSim_User.pdf or use cdsdoc/cdnshelp depending on the simulator version you're using).
    To reference the include file, use Setup->Model Library and then add the path to the incvector.scs file.
  • EveBell
    Hi Andrew.
    Thanks for your assistance. Is there anyway that I can include a digital vector file in a verilog netlist file?
    Again, Thx.
    I think (not really my field) you could use the "ncgentb" command to create a testbench from a VCD file. Probably a better question for one of the more functional verificaton/digital forums or for customer support.
