  3. two dimensional bus notation in schematics
  • Replies 7
  • Subscribers 139
  • Views 24145
mheshami
mheshami over 15 years ago
I have a circuit block with a bit array input, CB<2:0>
I use a 62-element array of this block in a schematic.
How should i name the resulting two-dimensional input.
I tried the following and none of them worked:
CB<2:0><61:0>
CB<2:0> <61:0>
CB<2:0>;<61:0>
CB<2:0:61:0>
CB<62:2:0>
CB<.........
62*CB<2:0> is a valid syntax, but is not what I want, because it is really a one-dimensional array and shorts the inputs.
Any help would be appreciated.
  • Quek
    Quek over 15 years ago
    Hi mheshami
    As of IC615-500-1, it is not possible to specify a 2D notation in the schematic editor. Work for this feature is still on-going. Kindly file a request for this enhancement and include reference to CCR518271.
    Best regards
    Quek
  • Blagomir
    Blagomir over 13 years ago
     Hello Quek,
    I wonder if you can provide an update on the "two dimensional bus notation in schematic" enhancement status (CCR518271)?
    Blagomir
    Blagomir,
    Nothing concrete has happened yet and it is not yet planned for a coming release. The primary issue is that the OpenAccess database does not support this (I believe), and whilst it potentially could be emulated, that's not happened yet - this is part of a bigger project.
  • ChristerJ
    ChristerJ over 11 years ago
    Is there any news on two-dimensional bus notation? I have also missed this function a couple of times.
    Regards
    Christer
    Christer,
    There has been no change on this. It's still not planned.
  • MokranDahouman
    MokranDahouman over 10 years ago
    Hi everybody,
    Is there any news on two dimensional bus notation in schematics since the last year ?
    Thank you
    Regards
    Mokrane.
    No.
