  3. Regular expressions in a schematic search
  • Views 15117
J Wilwert
J Wilwert over 15 years ago
I want to use regular expressions in the schematic search tool - "Schematic Find".  As an example I want to find all schematic references of instances other than from libraries X and Y.  How do I do this using the popup schematic search tool in Cadence 5.14?
John Wilwert
  • Quek
    Quek over 15 years ago
    Hi John
    It is not possible to do it because the user expression in the search tool is meant to be just a single word. You would need to use a skillscript to do it. A simple top level search can be done using the following:
    procedure( mySearch()
       let( (cv target)
          cv=geGetWindowCellView()
          target=setof(x cv~>instances (x~>libName != "libX" && x~>libName != "libY"))
          geSelectFigs(target)
       ) ;let
    ) ;procedure
    Best regards
    Quek
  • J Wilwert
    Quek,
    Thanks for your reponse on this issue. (Frankly, I had given up hope that anyone would repond!)  I'll work with th escript you have provided - I'm certain it will work!
    Again, THANKS!
    John Wilwert
