  3. Virtuoso - how can I create an instance from a .inc HSPICE...
  • Views 4142
Virtuoso - how can I create an instance from a .inc HSPICE file?
Alex2kdl
Alex2kdl over 15 years ago
Hi, I am facing a problem with Virtuoso that I can't seem to solve. I am designing a circuit that uses a new component. This component has two terminals and I have an HSPICE .inc file that describes it as a sub circuit. The file is of the following format: .SUBCKT COMPONENTNAME n+ n- .PRINT R(component) . ++(.PARM, behvioral sources, MAX, MIN, etc are used here) . .ends COMPONENTNAME I would like to create a schematic instance for the component so that I can easily use it. How do I do this? I suppose that I have to create a new cellview of name COMPONENTNAME and I also suppose that I will have to include the .inc file in Analog Environment. How do I get the cellview to "point" to the .inc file, though? Could anybody refer me to some tutorial or help file? Also, is it sufficient to select "Use SPICE netlist reader" in analog environment to get Spectre to properly process the .inc HSPICE file? Thanks a lot! -Alex
  • Quek
    Quek over 15 years ago
    Hi Alex
    You can do it as follows:
    a. Create a cell that has a symbol with 2 pins n+ and n-
    b. Copy the symbol view as "spectre" view
    c. In ciw, go to "Tools->CDF->Edit" and select the newly created cell. Set to "base" cdf.
    d. Go to "Simulation Information" section and select "Spectre" as the simulator
    e. Set the name of the subckt as the value for "componentName"
    f. Ensure that "termOrder" is the same order as the netlist
    g. Add "simulator lang=spice" as the first line in the netlist
    h. In ADE-L, go to "Setup->Model files" and add the netlist as one of the model files
    You can now use the symbol in your schematic for simulation. COS solution 11208254 explains the above steps.
    Actually "spice netlist reader" or more commonly known as "spp" is just used to pre-process a spice netlist and convert it to a spectre netlist. It will not really help in your case because you still need a way to represent the netlist in your schematic. The usage of spp is also no longer necessary because spectre can read in a spice netlist directly.
    Best regards
    Quek
