  3. PSS, PNOISE and Transient Noise
  • Views 28177
pcardoso73
pcardoso73 over 15 years ago
Hi all,
 I have several questions which i will describe by topics. All the circuit design is made in Candence using Spectre.
 1 - As transient noise introduces noise in the transient simulation, I export the data to Matlab to perform the Jitter (RMS and Peak-to-Peak) calculations. How can I do this in Cadence ?
2 - How can be compared the results obtained from MatLab (from Cadence exported data), and those obtained by cadence ?
3 - What kind of noise is introduced by transient noise ? Can this noise be upconverted into phase noise ?
4 - Calculating phase-noise using PSS+PNOISE, if done with transient noise on, will affect the phase noise analysis result ? Should I disable the transient noise, when performing PSS and PNOISE ?
 5 - I am designing a VCXO for a PLL. The requirements are: frequency - 80 MHz, tunning range - +- 8 kHz, cload 15 pF. To simulate this circuit with transient noise I have used the following parameters:
Noise Fmax 1e9
Noise Fmin 10k
Noise Seed 1
Noise scale 1
Noise Tmin 4u
Is this correct ?
Thanks To all.
Best regards,
Pedro
    Pedro,
    To try to answer your questions:
    1. You can either import the results into Matlab using the "spectre toolbox" for Matlab (covered in the documentation), or in ViVA you can use File->Save from the results browser to save into Matlab form.
    2. Presumably you could compare them in Matlab?
    3. Transient noise is including the same as a small signal noise source. If using noisefmax only, you get white noise at noisefmax across the whole spectrum. If you specify noisefmin you get coloured noise (i.e. flicker noise) from noisefmin upwards. Yes, the noise is up and down converted. Bear in mind that you get the signal containing both the signal and the noise.
    4. PSS+PNOISE are completely independent from transient noise. PSS+PNOISE will be a much more efficient way of simulating the noise in a periodic circuit - and probably more accurate - unless the circuit has a large signal response to the noise.
    5. It depends! Very hard to know without looking at the circuit. Why do you want to use transient noise rather than PSS+PNOISE anyway?
  • pcardoso73
    Thanks for your answers.
    Relating to point 4, so if I choose either transient noise analysis or transient analysis without checking the transient noise analysis, the result of the Phase-Noise/Jitter calculations will be the same on the two cases, right ?
    Relating to your question in point 5, I was using transient noise to calculate the value of jitter in Matlab (both Jcc and Peak-to-Peak) and than to draw an histogram.
    I have as well calculated the Phase-noise under Cadence (as described in the manual), and I have used another approach integrating the waveform (being the units linear). The value of RMS Jitter that I have obtained is completely different from the calculated one and the one given by the Cadence simulation
    Regarding the circuit, is a basic Crystal Pierce oscillator (three-point oscillator), being the crystal modeled by an RLC series.
     Thanks a lot,
    Pedro
    Pedro,
    The results of the pnoise will not be affected by whether you are running transien tnoise or not.
    Note that integrating the result to obtain the jitter is not necessarily correct - because you need to be aware of the fact that there is a log relationship, plus the fact that if you're doing multi-cycle jitter you can only integrate over the band which you've simulated in the pnoise analysis. I suggest you take a look at the Jitter app note that is in <MMSIMinstDir>/tools/spectre/examples/SpectreRF_workshop . I don't know how you've calculated it or what you're comparing with.
  • pcardoso73
     Thanks a lot. I will take a look at the Jitter app.
     Best regards,
    Pedro Cardoso
  • larrywan
    larrywan over 7 years ago in reply to pcardoso73
    I have the same problem with you. The integral noise obtained by matlab is different from that obtained by cadence. Do you know why now?thank you
    community.cadence.com/.../jitter-simulation-pss-pnoise-and-matlab-get-different-results
