  3. *Error* Unable to establish connection with WaveScan
  • Views 15829
Sirisha
Sirisha over 15 years ago
I get the above error when i invoke ADE. Iam using IC5.1.41 on ubuntu 10.1. I have not faced this problem when i used IC5.1.41 on ubuntu 8.1. wavescan used to work fine on ubuntu 8.1 By using AWD as waveform viewer i can avoid this problem but not solve it. Could you please let me know what could possibly be the reason for the above error and how can i fix it.
  • Quek
    Quek over 15 years ago
    Hi Sirisha
    Would you please check if hostname and IP address from output of "hostname" and "ifconfig" cmds matches the same info in /etc/sysconfig/network, /etc/hosts and /etc/sysconfig/network-scripts/ifcfg-eth0?
    Would you please provide the following information?
    terminal>icfb -W
    Quek
  • Sirisha
    Hi Quek, I had two paths specified for utils. i commented one and its working fine now. Thank you
