  3. feedback
  • Views 16188
feedback
sam andro
sam andro over 15 years ago
i am designing a certain IC that has an internal feedback (based on transisto level), how can I make initialization for the internal feedback?, as it makes the simulation locked.
  • Quek
    Quek over 15 years ago
    Hi Sam
    In ADE-L, you can use "Simulation->Convergence Aids->Initial Condition" to set the initial voltage values for spectre simulation.
    Best regards
    Quek
  • sam andro
    Hi Quek:
    It did not solve the problem, the simulation still gets locked once i apply the feedback, but if
    I break the feedback the simulation is working properly but the result has to based on the feedback.
    any clue?!
    Regards:
    Sam
  • Quek
    Hi Sam
    Does "simulation gets lock" means that spectre hangs during simulation or spectre gives convergence error? May I have the following info?
    terminal>spectre -W
    Best regards
    Quek
  • sam andro
    Hi :
    I do not know where is this information terminal>spectre -W?
    but what I mean it is like the attached photo, where 2 inputs and gate, oneof the inputs is the inverted output, so it looks like a locked loop?
    Regards:
    sam
  • skillUser
    skillUser over 15 years ago
    Hi Sam,
    What Quek is asking for is the result of typing "spectre -W" at the Unix terminal (without the quotes) - this will show the version of the Spectre simulator.  I'm not sure why that caused you any confusion?
    regards,
    Lawrence.
  • sam andro
    thansk guys
    I have fixed it
    Regards;
    Sam
