  3. ADEXL - psf cross reference file?
  • Views 1045
BradW
BradW over 15 years ago
Hey all, I'm quickly becoming addicted to using ADEXL but I occasionally still need to run scripts and such outside the environment. One thing that is difficult is finding the psf file that corresponds to a corner. What I'd like to have is some sort of cross reference file that lists the variables and corners with the appropriate psf file. Is anything like this available? Thanks
    There's a new function in IC615 called axlReadResDB() which returns info on what's in each corner and point and so on. That would allow you to write some code to get this kind of information, I believe.
