  3. setup Distibuted processing in ADE L
  • Views 17690
edafans
edafans over 15 years ago
I'm installed ic5141( subversion 135) on rhel5 and configured SGE 6U4
Have queue on SGE cluster:
all.q (8 hosts)
2host.q (2 hosts)
I have read the distproc.pdf file
I'm vi a  queue_config_file for flowing
all.q 8
2host.q 2
I hat to set :setenv LBS_CLUSTER_MASTER mnode ; setenv LBS_BASE_SYSTEM LBS_SGE
and added asimenv.distributed  copyMode boolean t, asimenv.distributed loginShell cyclic "csh", asimenv.distributed remoteShell "rsh", asimenv.distributed queueName string "2host.q" in .cdsenv file
but when I used  cdsqmgr process was run with queue_config file
[root@mnode software]# which cdsqmgr
/software/cadence/IC5141135/tools/bin/cdsqmgr
[root@mnode software]# /software/cadence/IC5141135/tools/bin/cdsqmgr  /software/queueconffile
[root@mnode software]# Incorrect config file format!
Check config file format and try again!
(i haven't understand yet, how queue_config file works)
It say in distproc.pdf
Syntax:
queue_1_name     N_-_number_of_hosts_in_queue_1
host_1                    job_limit_for_host_1_on_queue_1
host_2                   job_limit_for_host_2_on_queue_1
host_N                 job_limit_for_host_N_on_queue_1
but  i haven't understand yet,give me  a queue_config_file example ,Please.
 What 's mean /software/cadence/IC5141135/share/cdssetup/lbs/SGE/README.TXT
May I modfiy it for use DP?
(declareJobProfile
     "/Generic/nightly" ;; By convention, leafnames begin with a
                        ;; lower-case letter; directories begin with [A-Z].
;;     (versions "5.3") ;; IF versions are specified, the profile will
                        ;; be ignored unless the current DRMS integration
                        ;; version is specified.
     ;;---- Begin Job Submission Attributes
;;     (setq JOB_NAME           ;; qsub -N "job_name"
;;           "my_JobName")
;;     (setq LOGIN_SHELL        ;; qsub -S "shell"
;;           "/bin/csh")
;;     (setq QUEUE              ;; qsub -q "queue_name"
;;           "farmhost01.q,farmhost02.q,farmhost03.q")
     (setq MIN_BEGIN_TIME       ;; "2002/09/18 16:47:27 -07:00"
           "20:00")
     (setq MAX_END_TIME
           "08:00")
;;     (setq EMAIL_TO           ;; user[@host] [...]
;;           "chris" "kelly")
;;     (setq BLOCK_EMAIL        ;; "0" (allow mail) or "1" (disallow mail)
;;           "0")
;;     (setq SGE_HARD_RESOURCES ;; qsub -hard -l "hard_resources"
;;           "myHardResources") ;; name=val,name=val,...
;;     (setq SGE_SOFT_RESOURCES ;; qsub -soft -l "soft_resources"
;;           "mySoftResources") ;; name=val,name=val,...
;;     (setq SGE_VALIDATION     ;; qsub -w "validation"
;;           "w" )              ;; e|w|n : error, warning, none
;;     (setq SGE_PROJECT_NAME   ;; qsub -P "project_name"
;;           "myProjectName")
;;     (setq SGE_ACCOUNTING_NAME ;; qsub -A "accounting_name"
;;           "myAccountingName")
;;     (setq SGE_PRIORITY       ;; qsub -p "integer_priority"
;;           "0")
node02.ocs5> adptest
BEGIN Artist Distributed Processing Setup Test
Testing for existence of LBS_CLUSTER_MASTER variable...
    PASSED.
Testing opening of Artist Job Server...
Launching Artist job server...
Waiting for Artist job server to initialize (will keep trying for 24 more seconds)...
Waiting for Artist job server to initialize (will keep trying for 21 more seconds)...
Waiting for Artist job server to initialize (will keep trying for 18 more seconds)...
Waiting for Artist job server to initialize (will keep trying for 15 more seconds)...
Waiting for Artist job server to initialize (will keep trying for 12 more seconds)...
Waiting for Artist job server to initialize (will keep trying for 9 more seconds)...
Waiting for Artist job server to initialize (will keep trying for 6 more seconds)...
Waiting for Artist job server to initialize (will keep trying for 3 more seconds)...
*Error* eval: undefined function - _msgHandlerEMI
*Error* load: error while loading file - "/software/cadence/IC5141135/tools/dfII/etc/tools/adp/adptest_enc.ils"
edafans
    cdsqmgr and the queue_config file are only used if you're using the basic "LBS" system. They are not used for SGE - so you do not need to worry about setting that.
    You should just have to set LBS_BASE_SYSTEM (not LBS_CLUSTER_MASTER). Nothing else. I don't think you really need the job profile stuff either - I've never actually played with that though.
  • edafans
    Hi Andrew,thinks for your help.
    I'm only set  LBS_BASE_SYSTEM  LBS_SGE in .cshrc
    ERROR (33) : A connection could not be established to the LBS queue
    Please help me agen that how  to configure DP in ADE L whith LSF or SGE
    Please write  carefully
    Since I'm rather busy over the next few days with my "day job" (responding on this forum is something I do in my spare time), I would suggest contacting Customer Support to help debug this. There is also a button on the Setup->Simulator/DIrectory/Host form in ADE to check the setup - that may reveal something useful.
