  3. cdd or cddbo
  • Views 17779
cdd or cddbo
Malolo
Malolo over 15 years ago
can anyone kindly explain the difference between cdd and cddbo (and cgg/cggbo etc), or simply put, which one should I use as the drain-to-substrate capacitance?
thank you!
Malolo
    Malolo,
    I could probably guess, but which model are you talking about (bsim3v3, bsim4, widget72 - OK, I made that one up) and which simulator are you talking about? It rather helps to give a precise answer rather than one which is based on a number of guesses.
  • Malolo
     Thanks for the reply, I'm using BSIM4 model, and the simulator is spectre
    Malolo
     Hi Malolo,
    From the documentation (spectre -h bsim4) it says:
    23      cdd (F)           Drain capacitance, including intrinsic, overlap, and
                              fringing components.
    44      cddbo (F)         CDDBO = dQd/dVd intrinsic drain capacitance
                              (alias=lx33).
    From this I'd guess that cddbo doesn't include the overlap and fringing components. However, I'm not really sure. I do have a CCR at the moment asking for greater detail (and equations) on what the operating point outputs mean - so enhanced documentation. Hopefully we'll have something in the near future.
    In the meantime a question would probably need to be asked of R&D, so you should log a service request if you need more detail.
