  3. Generate Schematic from Verilog Netlist - undefined function...
  • Views 2325
Generate Schematic from Verilog Netlist - undefined function ipcBeginProcess
gwong
gwong over 15 years ago
I am trying to create a schematic view from a gate-level verilog netlist from the "File-> Import -> Verilog... " menu in the CIW window.  I'm getting the following error:
*Error* eval: undefined function - ipcBeginProcess
ERROR (VERILOGIN-205): An internal memory error has occurred. Exiting.
 I've checked memory usage and it appears to be fine.
 I'm using IC6.1.5
Thanks for your help.
Gary
  • skillUser
    skillUser over 15 years ago
    Hi Gary,
    Are you using the first customer shipment (FCS) version of IC6.1.5, or an ISR (e.g. ISR1 or ISR2) (what does getVersion(t) report) ?
    Does everything else work correctly?  Are you running "virtuoso" from the Unix prompt to start the session, or something else? I am concerned that the virtuoso installation does not seem to have the ipcBeginProcess function defined - it is a low-level built-in function, not even a function that is written in SKILL and loaded through a context file.  So my thoughts are, if ipcBeginProcess is really missing, is the installation "complete"?  I did not see the above error in our database, by the way.
    Lawrence.
  • gwong
     Hi Lawrence,
    Thanks for your prompt response.
    getVersion(t) reports "sub-version  IC6.1.5-64b.72 "
     We've only used this version for about a week or 2 now and everything seems to be working, except, waveform viewer problem (I've been notified of a fix coming in June, I think). I type "virtuoso" at the Unix prompt to start the session.
    I will check with my IT to see if there were any issues with the installation.
    Gary
