  3. viaStackSelection
  • Views 15019
viaStackSelection
Henri Revet
Henri Revet over 15 years ago
In .cdsenv the command:
     layout  viaStackSelection  boolean nil
does not work.
CIW gives me this message:
     *WARNING* envSetVal: Can't set the value of variable 'viaStackSelection',
     in tool[.parttion] 'layout' - it has not been registered.
Somebody has an idea what 's wrong ?
Thanks.
  • skillUser
    skillUser over 15 years ago
    Hi Henri,
    The setting is not for the tool "layout" but for "graphic:
      graphic viaStackSelection boolean nil
    There are some viaStack* prefix variables for the layout tool, however:
      layout viaStackRows int 1
    layout viaStackColumns int 1
    layout viaStackMode cyclic "sameFootPrint"
    The above settings can be found in your installation hierarchy at <cds_root>/tools/dfII/etc/tools/layout/.cdsenv (or substitute "graphic" for "layout" to see the graphic variables, and so on for other tools)
    Hope this helps!
    Lawrence.
  • Henri Revet
    Hi Lawrence,
    The Cadence help is showing "layout" for this variable.
    They must be wrong.
    It is working now with "graphic".
    Thanks a lot.
    Henri
  • skillUser
     Hi Henri,
    I searched in COS for "viaStackSelection" and I only see a match for it in the IC615 documentation, and this correctly shows the variable for "graphic" - if I see a mistake in cdnshelp I will file a bug report against it, but I think that COS uses the same documentation source as the tools, so I would only to expect to find a mistake in an older release (say IC615 First Customer Shipment version) since COS does not have an error (which may mean there was a mistake which then got fixed in an ISR).
    However, I am glad that it this is now working for you, and I am happy to have helped.
    Best regards,
    Lawrence.
