  3. vias and nets from spaced base router
  • Views 14225
Brouns Robin
Brouns Robin over 15 years ago
Hi everybody,
I started a new project and it's in Cadence 6.1.5 virtuoso. As my experience in IC6 is small, i hope you could help me a bit. I have 2 small questions about the space based router.
  • Why are the vias not nicely aligned to the pins?
  • And why doesn't the router follow my configuration of the wire assistance? More specific the routing directions of the metals.
I added a screenshot to illustrate my situation.I'm trying to connect 2pins to 3thparty cells and I'm using M2,M4 vertical and M1,M3 horizonal.
Click on the image to enlarge
Thanks a lot,
Robin
