  3. how can i increase the width of pmos upto 873.6um
  • Views 15267
1234v
1234v over 15 years ago
 hai all;
   in UMC_18_CMOS  how can  i arrive at width of a PMOS of about 873.6um
thank you all
  • Quek
    Quek over 15 years ago
    Hi 1234v
    Perhaps you can use the "m" factor? : )  It creates multiples of the same instance. There is most likely an entry for "m" in your schematic/layout properties form for the pmos. As an example, you can set an m-factor of 100 and set W to be 8.736um. You will then be able to get a total W of 873.6um. Hope that this is what you are looking for because the question is not very clear.
    Best regards
    Quek
  • 1234v
     thank you
     quek
